Is it possible for an EFIlive user to define GM PIDs that are not listed in the current PID list?
i.e. transmission PID's such as TCC pressure & Transmission Fluid Temperature - Substrate: TFTS (vs TFT).
Cheers.
Cheers.
On a somewhat related note, (hopefully not a threadjack!) is there an ETA for additional A6 parameters to be released? The EFILive competitor has released many more tables for the A6 transmissions which would be very beneficial (see attachment) for EFILive users as well.
I don't mean to complain, as I know the EFILive staff is very busy and doing great things for this market. If EFILive doesn't plan to add these tables I will purchase HPT for transmission tuning.
Which parameters exactly are not available in EFILive? Sometimes the same parameters are called different things in EFILive. If you provide a list of which parameters you think should be in EFILive we can tell you if they are there and just called something else, or we can add them in for the next release.
In future dont wait, hoping we will put parameters in, the sooner you ask for them the quicker we will add them in.
Hi Paul,
This goes through what the competition offers: http://www.thetuningdoctor.com/HPTun...parameters.swf
They have since added more parameters to torque management as well, currently in beta (see attachment).
I am particularly interested in being able to modify downshift calibrations, from braking to WOT. These include most items under their "shift properties" tab. Also interested in better control of torque management, beyond simply on/off.
Is there a way to log downshifts? I see PIDs for Last (1->2, 2->3, 3->4), but 4->5, and 5->6 still seem to be missing for the 6 speed boxes, as well as a way to log any downshifts. "last shift time" doesn't seem to monitor downshifts.
These 6 speed boxes seem to use some incredibly complex logic! There is some great discussion going here: http://www.hptuners.com/forum/showth...ht=walkthrough. It's no longer simply a matter of selecting your speed and shift time for each shift as it was for the 4 speeds!
Thanks in advance,
Josh
Also please: Parameters such as TUTD Options: Disabled/Enabled, Direct/Serial, Range Select Enabled/Disabled, Active Range. Ability to select function of each of the forward 4 manual shift positions.
And TCC PWM/Pressure/Torque Parameters.
Would guess you got plenty of very market relevant feedback at SEMA.
Cheerz.
Can you resend this to my email: paul@efilive.com that way it will get into the development cycle.
