Results 11 to 20 of 25
Thread: bigger injectors and fuel pump
    Nov 2007
    Quote Originally Posted by 5.7ute View Post
    If the 42lb injectors are rated at 3 bar(like I am pretty sure they are) Your ifr table is wrong. Since you are running a vac referenced regulator you should have a constant value of 6.1107 at 58psi fuel rail pressure.
    I'm not shore how you came up with that but here xls sheet i used.
    info about the injectors.
    Static flow @ 37.95lb/hr @ 43.5PSI / 300KPa (4.31 g/s = 398cc/min)
    Static flow @ 43.82lb/hr @ 58PSI / 400KPa (4.97 g/s = 460cc/min) *
    Dynamic flow (2.0ms/10.0 ms(pulse width / rep rate)) 6.0 lb/hr @ 43.5PSI (0.748 g/s @ 300KPa)
    Coil Resistance: High Impedance / High-Z (Works with factory computer injector drivers)
    Factory Tollerance: +/-5%
    Connector: Multec 2 (Delphi)
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    Nov 2007
    Quote Originally Posted by nevinsb View Post
    I would question whether the injector flow rate was calculated correctly if it was running fine before the injectors were replaced. There is an injectors.xls file floating around the internet that I have found quite helpful. Otherwise it was possible that someone previously had tuned the PCM with incorrect. If this is the case, you will have to run through the auto-ve again.
    Where'd you find the waldo pump?
    send me a pm and give some links to get the waldo pumps.
    Quote Originally Posted by CoryF View Post
    aaronr,
    One time I was messing with my tune and I changed the Injector Flow Rates for a new racetronix fuel pump. When I did this it threw off my AFR.
    One good thing about changing the IFR is that it was a constant value that gets adjusted. Once I changed it back to the flow rate that I wanted. I did a "short" AutoVE and then was able to use that data to tell the BEN factor that all the cells should have been off by. Then I changed the Main VE table with that factor for the daily driving cells (the ones that get 50+ hits during AutoVE). Then did a complete AutoVE so that I wasn't running around real rich/lean.
    I don't know if that makes sense, I chopped it up a lot as I was typing. lol
    I attached a excel spreadsheet that will help.
    Excel spreadsheet --> USE THE ONE ATTACHED IN THE NEXT POST
    -CoryF
    I'll check out.
    Okay so I decided to make the spreadsheet a little easier to understand. Let me start off by saying that I did not make this entire spreadsheet, I got it from another member and added more parts to it to help adjust the MainVE table when you change the Injector Flow Rates.
    The new spreadsheet is quite simple and is a lot like the last one.
    -The first table you paste your BEN's into (the only place you should paste)
    -The second table tells what percent rich/lean each cell was
    -The third is the "smoothed" value that you should paste into your MainVE table
    -The forth is "new" follow the directions and it will either be populated with:
    1. The average BEN Factor from the first table
    OR
    2. A set value that the user has predetermined
    I hope this helps you dial in your AFR with a new IFR. PM or post up if you have any questions.
    NEW Excel Spreadsheet ---> Attachment 4203
    -CoryF
    I'll check out.
    2006 Trailblazer SS
    Oct 2006
    Using that data IFR should be 5.5213 on both spreadsheets.( Mine is set up for fuel pressure logging so is a bit later version.)
    The Tremor at AIR
    Dec 2007
    Quote Originally Posted by aaronr View Post
    I'll check out.
    I don't think I was on the right page as everyone else. lol So that might help you dial in the MainVE but if it has nothing to do with what your workin with just tuck it away on the ol hard drive and forget about it.
    I created it because when I changed my flow rate I set the fuel pressure too high so the flow rates were a little high, then did like 2 hours of VE tuning. I didn't want that all to go to waste so I loaded in the new tune and did a log to find out that all of the cells were off by about .96** so I used that spreadsheet to change the cells back to a 1.0** BEN.
    My theory behind the spreadsheet was that the IFR is used to calculate how long to hold the injector open for a certain amount of fuel. If someone were to over or underestimate the IRF values all the cells would be affected the same, therefor they can all be edited with the same factor.
    Like I said if you can use it, it'll really help, but if not I tried hehehe
    -CoryF
    2001 Camaro SS #2070
    -K&N FIPK, P/P TB, 227/231 .614/.617 111+4, UD Pulley, LT headers, OFY, Dumped 3" Exhaust, !AIR, KONI 4/4, Spec 3+ w/ Aluminum Fly Wheel, 4.10's, Custom EFILive Tune
    May 2008
    Which injectors are you using? The delphi 42LB injectors do not match those values:
    http://www.racetronix.com/17113813.html
    Delphi Part #17113813 (OE # 25324743)
    Manufacture Specifications (using gasoline):
    Static Flow Rate @ 43.5PSI / 300kPa : 42 lb/hr +/-5%
    Static Flow Rate @ 58.0PSI / 400kPa : 48.5 lb/hr +/-5%
    Dynamic Flow Rate @ 43.5PSI (300 KPa) = 0.945 gm/sec - 2.5ms pulse width @ 10ms repetition rate
    Coil Resistance: 12.0 Ohms / High Impedance / High-Z (Will work with factory ECM/PCM drivers)
    Spray pattern / angle : Cone @ 21.9 degrees
    Connector: Minitimer (Bosch EV1)
    Body: Top-Feed Multec 1
    Metering Technology : Ball/Seat Design with 6-Hole Diffuser Disc
    Electrical Connector : Minitimer / EV1
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Nov 2007
    Yes these are the injectors i'm using? What do you mean "The delphi 42LB injectors do not match those values:"
    2006 Trailblazer SS
    Nov 2007
    More info.
    2006 Trailblazer SS
    May 2008
    AARONR:
    NEVINSB:
    I was seeing significant differences between the flow rates listed at the same pressures, that's why I was trying to figure out which injectors you were using.
    48 LB injectors
    T70 turbo.
  9. #19
    Arn't the 42 lbers rated at 43.5 psi...?
  10. #20
    Nov 2007
    where i bought my injectors they rated for this
    2006 Trailblazer SS
  1. which walbro fuel pump
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2009, 03:42 AM
  2. Do I need bigger injectors or more beer!!!???
    By ssvolvo in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2008, 11:36 AM
  3. Tuning Bigger Injectors Help
    By BrianC98Z28 in forum Gen III V8 Specific
    Last Post: February 10th, 2008, 04:40 AM
  4. Fuel Pump Voltage
    By SV8346 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2007, 06:18 PM
  5. Modifying custom tune for bigger injectors
    By Garry in forum Gen III V8 Specific
    Last Post: December 3rd, 2007, 11:41 AM
