Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: bigger injectors and fuel pump
    Nov 2007
    Default bigger injectors and fuel pump
    Well replaced the injector with 42's and put a waldo 255 pump . I'm wounding if just need to redo my V.E table and short fuel trims were +35% when a/f came back around 15 then when rev up the trim go back to +5% and the a/f goes to 19.1 and works way back to 35% on the short fuel trims. I'm thinking I should redo my v.e table for the bigger injector. I'm running co3 sem-closed looped and changed my fuel rate already. 58 psi with no vacuum and 50 psi with vacuum.
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    May 2008
    I would question whether the injector flow rate was calculated correctly if it was running fine before the injectors were replaced. There is an injectors.xls file floating around the internet that I have found quite helpful. Otherwise it was possible that someone previously had tuned the PCM with incorrect. If this is the case, you will have to run through the auto-ve again.
    Where'd you find the waldo pump?
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Oct 2006
    Quote Originally Posted by nevinsb View Post
    It would help if you post your tune file.
    I agree with nevinsb in regards to the IFR table being incorrect either before the change or for the current injectors.
    The Tremor at AIR
    Dec 2007
    aaronr,
    One time I was messing with my tune and I changed the Injector Flow Rates for a new racetronix fuel pump. When I did this it threw off my AFR.
    One good thing about changing the IFR is that it was a constant value that gets adjusted. Once I changed it back to the flow rate that I wanted. I did a "short" AutoVE and then was able to use that data to tell the BEN factor that all the cells should have been off by. Then I changed the Main VE table with that factor for the daily driving cells (the ones that get 50+ hits during AutoVE). Then did a complete AutoVE so that I wasn't running around real rich/lean.
    I don't know if that makes sense, I chopped it up a lot as I was typing. lol
    I attached a excel spreadsheet that will help.
    Excel spreadsheet --> USE THE ONE ATTACHED IN THE NEXT POST
    -CoryF
    2001 Camaro SS #2070
    -K&N FIPK, P/P TB, 227/231 .614/.617 111+4, UD Pulley, LT headers, OFY, Dumped 3" Exhaust, !AIR, KONI 4/4, Spec 3+ w/ Aluminum Fly Wheel, 4.10's, Custom EFILive Tune
    Nov 2007
    Here is my current tune.
    2006 Trailblazer SS
    Dec 2007
    Quote Originally Posted by CoryF View Post
    Okay so I decided to make the spreadsheet a little easier to understand. Let me start off by saying that I did not make this entire spreadsheet, I got it from another member and added more parts to it to help adjust the MainVE table when you change the Injector Flow Rates.
    The new spreadsheet is quite simple and is a lot like the last one.
    -The first table you paste your BEN's into (the only place you should paste)
    -The second table tells what percent rich/lean each cell was
    -The third is the "smoothed" value that you should paste into your MainVE table
    -The forth is "new" follow the directions and it will either be populated with:
    1. The average BEN Factor from the first table
    OR
    2. A set value that the user has predetermined
    I hope this helps you dial in your AFR with a new IFR. PM or post up if you have any questions.
    NEW Excel Spreadsheet ---> VE_Interpolation_tables.xls
    -CoryF
    Dec 2007
    Shouldn't the IFR table {B4001} should be a linear graph, not a constant value...
    There is a Excel spreadsheet that you should do a search for that will give you the right values for that table based on your injectors. Just run a search for IFR spreadsheet.
    -CoryF
    May 2008
    I guess that would depend on the fuel pressure regulator too.
    48 LB injectors
    T70 turbo.
    Dec 2007
    The Excel sheet that I downloaded from somewhere you are able to change the fuel pressure for different Manifold pressures. From the factory the fuel pressure regulator should keep a constant fuel pressure that might fluctuate a little. If you are running a turbo car and have an adjustable fuel pressure regulator the graph would still be linear but would have a steeper slope.
    -CoryF
    Oct 2006
    If the 42lb injectors are rated at 3 bar(like I am pretty sure they are) Your ifr table is wrong. Since you are running a vac referenced regulator you should have a constant value of 6.1107 at 58psi fuel rail pressure.
    The Tremor at AIR
  1. which walbro fuel pump
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2009, 03:42 AM
  2. Do I need bigger injectors or more beer!!!???
    By ssvolvo in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2008, 11:36 AM
  3. Tuning Bigger Injectors Help
    By BrianC98Z28 in forum Gen III V8 Specific
    Last Post: February 10th, 2008, 04:40 AM
  4. Fuel Pump Voltage
    By SV8346 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2007, 06:18 PM
  5. Modifying custom tune for bigger injectors
    By Garry in forum Gen III V8 Specific
    Last Post: December 3rd, 2007, 11:41 AM
