Results 1 to 5 of 5
Thread: Tried to flash the PCM and got an error
    Nov 2008
    Default Tried to flash the PCM and got an error
    I am wondering if this is because I have a HPT 3 bar OS on my PCM. Hopefully someone can help me out with this.
    Error that I get is:
    Bootloader Rejected
    controller has returned to normal operation, please retry operation.
    Data transfer interrupted
    I unchecked the high speed and tried again and it did the same thing. Is there something that I am doing wrong or is it because of the HPT tune.
    Isn't that a HPT custom tune...?
    If so, I don't think you'll be able to read it or write over it.
    I pm'd tech support.
    Nov 2008
    Thanks, Yes it is a HPT Custom tune that is why I am trying to get rid of it cause my car will not start with this $250 custom mail order tune....LOL
    Sounds like the PCM is locked, which is quite common when a PCM has a custom OS installed. If you speak to the company that did the tune for you they should be able to return the PCM to stock and in doing so that will also unlock the PCM.
    Nov 2008
    K thanks...
  1. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  2. E40 PO601 (ECM Flash eeprom checksum error)
    By rally1 in forum Gen IV V8 Specific
    Last Post: September 28th, 2009, 02:01 AM
  3. LBZ Full flash update error...
    By 06Dmaxpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2008, 08:42 PM
  4. Please Help!! PCM will not flash!!
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2006, 05:22 PM
