hi can somone direct me so i can retard some timing under boost (6psi) because i looked and looked but cannot see where i have the option to correct this issue.
thanks
oh, have the v2 program
thanks
are you running a COS?
Post your tune up also..
it is for a 96 k1500 changed to a 0411 from a 2001 express van
Read up on the Custom Operating systems man... COS 3 is what i use.. its got all the special tables for what you want to do.
OS 02020003 is what im using
since your running a 12212156.. thats what you can run..
lemme know if you need some more help..
look in the tutorials, everything is there.
thank you i just need to find the time to read up
Hey John,
Are you using a 4l60 or 80 trans? P.M. me your E-Mail address and I will send you a COS3 tune to get you started. You will need to input your tune specifics into it.
Jeff
98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
