Results 1 to 6 of 6
Thread: need to retard timing under boost
    Sep 2008
    Default need to retard timing under boost
    hi can somone direct me so i can retard some timing under boost (6psi) because i looked and looked but cannot see where i have the option to correct this issue.
    thanks
    oh, have the v2 program
    are you running a COS?
    Post your tune up also..
    Sep 2008
    it is for a 96 k1500 changed to a 0411 from a 2001 express van
    Read up on the Custom Operating systems man... COS 3 is what i use.. its got all the special tables for what you want to do.
    OS 02020003 is what im using
    since your running a 12212156.. thats what you can run..
    lemme know if you need some more help..
    look in the tutorials, everything is there.
    Sep 2008
    thank you i just need to find the time to read up
    Aug 2006
    Hey John,
    Are you using a 4l60 or 80 trans? P.M. me your E-Mail address and I will send you a COS3 tune to get you started. You will need to input your tune specifics into it.
    Jeff
  1. Timing retard
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 10:25 PM
  2. Nitrous timing retard
    By PRAY in forum Gen III V8 Specific
    Last Post: December 12th, 2007, 06:49 AM
  3. Boost timing PID?
    By TNT76 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 24th, 2007, 08:52 PM
  4. 4 degrees timing retard needed
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2006, 02:42 AM
  5. Spark Boost retard table
    By hpcubed in forum Custom Operating Systems
    Last Post: May 24th, 2006, 08:03 AM
