Look at my commanded AFR. What gives? I have been unable to get this righted. Sorry, don't have WB hooked up at the moment (need bung installed).
Anyone have any insight?
This is primarily off the GM stock tune. I did try to richen it some, but no dice.... I don't think I can enough if Commanded AFR is what whacked out.
As long as I don't go in PE Mode, I don't get kR issues, but as you can see what AFR is when I DO go into PE mode.....
Mods? Gutted air box only.
