Results 1 to 3 of 3
Thread: Need help upgrading from V1 to V2 (error when upgrading)
    Member tunedportcj5's Avatar
    Sep 2006
    Default Need help upgrading from V1 to V2 (error when upgrading)
    So I finally purchased a V2 to upgrade from my V1. My V1 has a commercial scan and tune license and my new V2 is in upgrade mode when plugged in.
    On my laptop with v.7.5.5 already installed - I connected both the V1 and V2 and attempted the upgrade... Help ---> Flashscan V2 upgrade from the file menu. When attempting to "Show Existing Licenses" to compare the two, I get an error "Please connect both Flashscan V1 and Flashscan V2 interfaces and then try again". Well I have done that a million times, completely removed and reinstalled v7.5.5, removed and reinstalled the USB drivers. I have even installed 7.5.5 and the USB drivers on a PC I have never had EFI installed on... same issue.
    Both devices connect fine, I am able to view the licenses on each device - only when plugged in individually. It seems to be a problem when they are both plugged in.
    Any thoughts? My laptop is XP Pro (what I use for all of my tuning) and my desktop in Vista... same results on both machines.
    Any help will be appreciated! Thanks!!
    -David
    '94 Lexus SC300 LY2 4.8, LS6 cam/springs, E38, LS3 MAF, LS2 intake, 88mm TB, 2bar MAP, T42/4L80e, mpt70
    www.terratraction.com/gallery
    Jul 2004
    Paul says that it is imperative that you upgrade to the newest version of the software (V7.5.5 Build 73) and the hardware won't upgrade until you upgrade the software.
    In order to upgrade the software you need to click: start/all programs/EFILive/V7.5/tools/Check for new update.
    Ira
    Sep 2006
    Thanks Ira - I had the leatest version installed but its amazing what an update will do! It works now!! Thanks for your help!
  1. Upgrading a '99 to '01 PCM
    By turbo_bu in forum Gen III V8 Specific
    Last Post: March 30th, 2010, 05:17 AM
  2. upgrading o.s. ?
    By smslyguy in forum Vortec V6/V8 Specific
    Last Post: February 8th, 2010, 11:56 AM
  3. upgrading to 7.5.4.64 Q's....
    Last Post: July 27th, 2008, 04:12 PM
  4. Upgrading OS
    By Naf in forum Gen III V8 Specific
    Last Post: July 14th, 2007, 03:22 AM
  5. Upgrading to V7.3.3
    By Kiwi Ed in forum FlashScan V2
    Last Post: December 9th, 2006, 11:23 AM
