Thread: problems registering
    Nov 2008
    Default problems registering
    So i have efilive v6 that i havent used in about 2 years or so. When i connect to the vehicle it asks for the registration info and it wont accept it when i put it in. I remember when i used it last there was i special way i had to enter the letters for the registration. Also once connected none of the gauges work. Does it ahve to be registered for that?
    Nov 2008
    Nevermind i figured it out. The serial number had to have to extra 00 s in front of the #
    elitopus, welcome to the forum...
    Glad you got it.
    If you want to run V7 software, you can get a registration key (free).
    Nov 2008
    I could download the software at efilive.com ? Would they send me the new key with no problems? Also what is the difference between v6 and v7? Thanks
    Yes, you have to send your serial number and EFILive sends back the V7 registration key.
    There are many differences between V6 and V7...
    fixes,
    improvements,
    I don't remember...
    does V6 even do BBL on the V1...?
    Quote Originally Posted by elitopus View Post
    Download and install V7.5.5 and V8.1.2 from here:
    http://www.efilive.com/index.php?opt...=48&Itemid=124
    After installing, make sure you select the start menu options:
    Start->All Programs->EFILive->V7.5->Tools->Check for New Update.
    and
    Start->All Programs->EFILive->V8->Tools->Check for New Update.
    Then send your FlashScan or AutoCal serial number and V5 or V6 EFILive registration key to me at paul@efilive.com and I will send you back a V7 Scan Tool registration.
  1. V2 problems :(
    By CDR in forum FlashScan V2
    Last Post: March 2nd, 2009, 05:56 AM
  2. Got some problems
    By mwalls54 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2007, 09:05 AM
  3. RR usb problems
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 10th, 2006, 07:41 AM
  4. Having trouble registering efilive..
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2006, 03:20 AM
  5. Registering my EFI
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 12:21 AM
