Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: need info on swapping 4.3 to 5.7
  1. #11
    Aug 2006
    Have him leave the Express Van tune in it and put in your V.I.N. Have him turn off V.A.T.S. and delete Generator codes, put in your gear ratio and tire size while he is flashing it.
    Jeff
  2. #12
    Sep 2006
    Here's the list of vehicles that used the 12200411 PCM.
    Easy to find in junk yards.
    http://198.208.187.182/internet/Vehi...&part=12200411
  3. #13
    Nov 2008
    ok the computer i got is out of an 01 express van, the number is 12200411, is this the correct pcm? also will any vortec 5.7 4 plug wire harness fit it, thanks for the help!
  4. #14
    Nov 2008
    ok yes i just now nodiced the post obove mine ok then!!!
  5. #15
    Sep 2006
    Quote Originally Posted by 98_shortbed View Post
    You're cool now. To use the pcm, you need to make sure it is a 5.7/4L60E or whatever engine/trans combo you are running.
    Some of those trucks had 4.3/4L60E,5.0/4L60E, and also 5.7/4L80E combos. I've got most of the combos in TCII format. I don't know how they will transfer to EFILive, but you can probably find the right file here.
  6. #16
    Aug 2007
    If you want V.A.T.S. to be operational it still functions just fine. I did the 0411 swap in my vortec s10 4.3l and just did the 30 min relearn and all worked fine. Also if your truck is a 4x4 you need to use a 4x4 tune outta a s10 and just copy the engine segment over for the 5.7l.
    Later
    Kurt
  7. #17
    Aug 2008
    Im considering doing the swap. The 1998 Vortec computer(I'm finding out) doesn't even have half the parameters to mess with as the LSx style pcm....Would I just need to find a 0411 pcm that has a V6 tune in it to work with my 1998 V6 Vortec?
    FLASHSCAN V2 & AUTOCAL
  8. #18
    Feb 2006
    GAMEOVER, any 411 PCM will work. You will just need to put the correct OS and calibration file into it.
    Al
  1. Swapping 12200411 PCM into 98 Chevy Truck
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2017, 01:05 AM
  2. Swapping OS ?'s
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2009, 05:04 PM
  3. quick question about swapping PCMs
    By SimpleManLance in forum Gen III V8 Specific
    Last Post: April 1st, 2008, 11:43 AM
  4. 97 Vette Segment Swapping
    By Doc in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2007, 09:16 AM
