Results 1 to 6 of 6
Thread: WOT then can't get RPMs
    Sep 2008
    Default WOT then can't get RPMs
    hi it seems that when i use wot it will not go past 3500 and if i kick down say from 4th to 3rd (at 100km) it will jump to 4000 but it tries to jump back to 3500 max by surging hard and blowing black(too rich) but if i don't use wot i can get the rpms to 4000 (need more rome to climb any more) and then it seems to knock (too lean)
    is there somthing to do with WOT
    Oct 2006
    If you post up your current tune someone will be able to help you. A log file which shows the issue would also help.
    The Tremor at AIR
    Sep 2008
    i know that it is not a belt problem cause i was able to get a smaller one on with the help of a bent body clip remover tool and no slip marks on the painted part but still can't get past 4000 or a bad surge but if i decrease throttle to say 75% then it cleans up
    can't figure it out!!!
    here is a tune i am using
    Sep 2008
    maybe the fuel management unit is dumping too much fuel at 4.5 and up boost?
    Sep 2008
    oh and not to sure just how to get a log file from the truck ?
    Quote Originally Posted by JOHNGEAR View Post
    JOHNGEAR,welcome...
    - Connect FlashScan,
    - Start scantool and press connect button (green button at upper left),
    - Enter VIN/OS and Controller (File menu),
    - Validate pids (button at left of 2nd toolbar),
    - Select the pids you want to log (PIDs tab, keep channel count < 25),
    - Start recording (red button at bottom center),
    - When finished logging, stop recording (blue button, bottom center),
    - Save log, specify a filename.
  1. RPMs bouncing at 2-3 shift!
    By shadyst in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 8th, 2009, 07:50 PM
  2. Tach is off by about 200 rpms. Can I change this?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: January 22nd, 2009, 05:58 PM
  3. shift rpms tis rpm or engine rpms
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2008, 07:01 AM
  4. Need more rpms
    By smknmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2008, 09:39 PM
  5. Occasional KR @ medium RPMs?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 12:06 PM
