Results 1 to 3 of 3
Thread: Really need LMM>V2 Regen help asap!
    Apr 2007
    Default Really need LMM>V2 Regen help asap!
    I really need to force a service regen on a 08 LMM right now. When I click "Activate" in scan tool mode. It gives me a title bar saying "No reply" But I am connected to the truck. I can log driving conditions ect. I just cant get it to run any of the DVT controls.
    When is USB mode on the V2 the bottom right corner only says "CAN" no numbers.
    I updated to the most current 8.1 just now. I can open the efilive explorer but it doesnt work. It says its not responding.
    What could it be, I really need to force a service regen as I type.
    Thanks alot in advance!
    2005 GMC Sierra ec/lb LLY - stock-
    Have you also updated the firmware in your FlashScan V2 device?
    If not, read the document:
    Start->All Programs->EFILive->V8->Documents->Upgrading Firmware.
    Apr 2007
    thanks paul, I upgraded everything to V8.1 and it worked great!
  1. Help ASAP!!!!???
    By Mr.Blister007 in forum Duramax LLY
    Last Post: May 30th, 2010, 12:52 AM
  2. DPF Regen Effectiveness
    Last Post: May 19th, 2010, 07:08 AM
  3. I need some help ASAP
    By Sparky8370 in forum FlashScan V2
    Last Post: June 9th, 2009, 06:47 AM
  4. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
  5. manual regen on LMM's
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2007, 05:01 AM
