Results 1 to 5 of 5
Thread: Flashscan speeds?
    Jun 2004
    Default Flashscan speeds?
    Sorry if this has been asked and answered, I did a search and didn't find anything.
    Does flashscan use the high speed bus to program the PCM? I'm wondering if I'm still going to be stuck in slow-mo like I am now with Edit.
    Thx.
    FlashScan uses the high speed bus.
    Reflashing most PCMs takes just under 30 seconds
    Reading 512K of most PCMs takes around 1:50 seconds
    Reading 1Mb of Most PCMs takes around 3:40 seconds
    The above times are "best" case. If the bus is noisy and retries need to be perfomed then the data transfer time may extend by 10-20%.
    Jun 2004
    Paul,
    Thanks for the fast reply. I appreciate it.
    -Tony
    Nov 2004
    how much will the speed of the computer matter?
    I bought a P-2 300mhz with 128 ram will be upgrading to 256. with windows XP. will just be using it to tune the car
    Quote Originally Posted by koolrayz
    For just reflashing and reading the PCM the PC speed will not matter.
    I have tested both reading/reflashing on a Pentium 233MHz and it is the same speed as on a 1.5GHz P4. The bottleneck is the comms speed between the PCM and the PC. Even on a 233MHz machine, the CPU is only 4-10% busy while flashing and/or reading.
    However, to get the most out of the editor and scan tool you will want something faster. We are recommending 800Mhz or more. 1GHz+ is ideal.
  1. How to scan speeds faster than 158 mi/h (255km/h)?
    By Treurentner in forum Petrol / Gas
    Last Post: February 22nd, 2018, 12:58 PM
  2. Long Tubes make GTO stumble at low speeds?
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2008, 03:42 AM
  3. V2 flashscan with LM1
    By Xtnct00WS6 in forum FlashScan V2
    Last Post: June 7th, 2008, 12:50 AM
  4. Individual wheel speeds
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 01:30 AM
  5. FlashScan V2.0?
    By bobfo in forum General
    Last Post: October 7th, 2005, 02:20 AM
