Has anyone here setup a drive pressure sensor using EFILive? I've been looking around and found a 0-130psi sensor that has an output of 0-5v. I read in the scan tool manual on how to set it up, but it seems a little confusing to create a calculated PIDS. I would like to get this setup and start playing around with this since I feel it will be better to be able to log this data instead of just looking at the maximum from a gauge.
