Results 1 to 10 of 14
Thread: OK I have done my first logs and alredy need help...
    Senior Member exploder's Avatar
    Aug 2008
    Default OK I have done my first logs and alredy need help...
    I just got the whole thing setup last night and upgraded to COS5 with 2 bar map enabled. I went out and did a few logs and got the base part throttle stuff nailed to 1.0 through the BEN. My first problem arose today when I went to give it anything above about 30% TPS the car goes dead lean and starts to buck. I attached 2 log files the first showing what mainly just one spot with the lean spike and the other showing the same trend, but more driving around included. TIA
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
    Is your MAF still fitted on the vehicle? If so it will be confusing the ECM with different airflow readings compared to the 2-bar MAP. You must either remove the MAF or leave it in place but make the ECM think it has failed so that it will ignore it.
    Page 15 of the Custom OS tutotrial shows how to leave the MAF in place and make the ECM ignore it. You should have at least 1 MAF fail DTC showing when you check for trouble codes - that shows that the ECM is ignoring the MAF.
    Regads
    Aug 2008
    It is all setup correctly as far as the maf failing and the 2 bar now. I did realize that I was logging the psi instead of kpa for my BEN factors and that was screwing up some of the Auto Ve I was doing.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Some more info regarding units:
    Configuring units in scantool/tunetool:
    showthread.php?t=7585
    showthread.php?t=164
    showthread.php?t=1757
    showthread.php?t=2722
    Also, set these out-of-range parameters to in-range (see Out-Of-Range tab):
    A0001
    A0002
    A0012
    A0013
    A5602
    The tunetool displays the min or max allowed value (whichever is closer) for a parameter that is outside the min..max range;
    to set to in-range, enter the closer of min+1 or max-1 (if you follow my meaning), repeat on each out-of-range parameter, save the file...
    if you wanted the precise/exact same min or max value, then also do the following:
    close the tunetool, reopen the tunetool, set the previously displayed min or max value on the same parameters, save the file.
    Default More comments/questions...
    Hi exploder,
    Do you have a manifold-referenced FPR...?
    In the tunetool, go Edit->Properties->Display and set:
    - VE units to g*K/kPa,
    - Fuel units to AFR or EQ.
    Why do the last 2 columns in B3605 go lean...?
    What do the minor peaks/valleys in B3618 represent...?
    B3801 is enabled... I would still disable it even tho B4205 is maxed/disabled.
    Be sure to log DYNCYLAIR_DMA so you can correlate to spark table B5913.
    Aug 2008
    I have a boost referenced FPR and have dropped the base pressure to 42psi. I followed the tutorial and maxed the values that it told me to and I guess that is why they are out of range. I am going to go back and check a few things you guys mentioned and do some more logging in the morning and report back on how it did. I went to the racetrack today and got the ve pretty close for on and off boost.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Aug 2008
    For some reason when I try and type in B3605 it shows that it doesn't exist "B3605 not found"?? What is that all about?
    I also have no idea why there were peaks and valleys there. I changed it all to 11ish to be on the safe side; or do you think I should set it elsewhere for a high boost application?
    Here is a another tune file attached so you can maybe have another look after I modified it some. I also smoothe the spark and VE's quite a bit by hand. I will go out and log some tommorow and see if it helped.
    Lastly now when I really get down on the gas I am hitting the 1514 code everytime...can somebody trim my VE and IFR appropriately to get me started or is there a new better way of doing it by now?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Ooops... my mistake, I meant B3647 not B3605... (the COS B3647 table replaces the B3605 table from non-COS).
    I was just curious about the ripples in B3618.
    Don't smooth VE's too much... operate the throttle as smoothly as you can ("good data") and apply the BEN filter (if you can think up a better filter, then edit it) to ignore "bad data".
    P1514: see tables C6101 and C6102... they work together, but I'm not sure how...
    maxing out C6101 will be as bad as having it too low;
    there's a few threads about this somewhere here...
    Quote Originally Posted by exploder View Post
    I have a boost referenced FPR and have dropped the base pressure to 42psi...
    Did you measure the rail pressure with the manifold reference hose removed...?
    What did the gauge read...?
    This is the pressure you enter into spreadsheet.
    e.g. gauge pressure is 42 psi, then 96*sqrt(42/43.5) = 94.33 lb/hr = 11.885 g/s.
    More info: http://forum.efilive.com/showthread.php?t=4821
  1. Adding logs together?
    By hquick in forum General
    Last Post: July 21st, 2010, 02:42 AM
  2. Can't get logs from v2 to PC
    By 1BadAction in forum Black Box Logging
    Last Post: January 8th, 2010, 07:58 AM
  3. Track Logs KR
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: October 20th, 2008, 04:55 AM
  4. cant review logs
    By charcold-bowtie in forum General
    Last Post: May 26th, 2008, 05:03 AM
  5. logs
    By way2much_01 in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 11:52 AM
