Results 1 to 10 of 15
Thread: Dtc 040 & 041 ?? EGR codes...
    Default Dtc 040 & 041 ?? EGR codes...
    Trying to stop a DTC 040 & 041 from tuning the check engine light on my o.s7083 LMM. It comes up as EGR codes and I do have a EGR plate installed and also have lost the remote start on my truck. Truck fires and shuts right down. Can anyone help with the fix?
    Thanks Nick.
    Junior Member Schweinmesser's Avatar
    Oct 2008
    monitoring thread....
    Nick, what's the full DTC code?
    P041D - no description
    P040D - no description
    P2457 - Exhaust Gas Recirculation Cooling System Performance
    P2033 - Exhaust Gas Temp. Sencor Circuit High bank 1 Sencor 2
    Oct 2008
    I just looked at my tune, which is stock minus DPF, and it shows under DTC Enables {C6001}: (My OS is 8594)
    P041D,P041C X: Not Reported, No MIL
    P040D,P040C X: Not Reported, No MIL
    P2457 "Exhaust Gas Recirculation Cooling System Perfomance" X: Not Reported, No MIL
    P2033 - P2032 EGT Sensor 2 X: Not Reported, No MIL
    Along with the P2033, I set P0546 - P0545 to X: Not Reported, No MIL
    because I have the sensors unplugged.
    If I pull DTC using the Flashscan V2, I still get the P2033, P0545, and P2455, but no MIL light. If I pull DTCs using the Banks PDA, I get no codes. Go figure.
    What do you have those DTC Enables set at in your tune?
    -Ronnie
    OK..so I just looked at my 7083o.s and it will not let see or turn the 040 & 041 off. Then I opened up a 8594o.s and you are able to pull it up and turn them off.
    So, I did have someone tell me that the truck may need to get re flashed but I also am trying to fix my truck and 1 other with the same issue and 7083o.s. I don't know if we can get that truck re-flashed.
    Next question, what are we going to loose if we are going to loose rather gain by re-flashing to a 8594o.s? Performance?
    Oct 2008
    Well, mine got the reflash in August as per the recall notice for the no-start issue, that I didn't have. I heard that this reflash was the one that would start logging CVNs and stuff, could be wrong though. After getting the reflash, I noticed that the truck would go longer before regenerating. I still had that thing on then. Other than that, I don't know what you would loose/gain performance wise.
    OK... I remember we talked about that when you where here. I need to look into that now also to see what way I want to go.
    Thanks Ronnie!!
    Jan 2006
    Quote Originally Posted by Schweinmesser View Post
    I thought all LMM's logged cvn's, even the early 07 OS. Can somebody verify this?
    04 LB7
    2010 LMM
    2015 LML
    Feb 2008
    Nick (nor-cal) can you give me a call when you get time. I had same issue, got part of it fixed. I think it may work for you. Curious on what tune your running, I am running the same OS and have not had the re-flash, nor will I
    Mike @ 702-885-6958
    We'll post up what we find out lol.
    12 Second LMM
    Feb 2007
    Any update on this? I'm having a similar issue right now. I have codes P2033, P2455, and P0546 that keep popping up despite being set to X:Not Reported, No MIL. Anyone have any help for me on why these codes will not go away?
  1. E38 & Codes
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: March 31st, 2009, 04:07 AM
  2. Error Codes
    By Chevy366 in forum FlashScan V2
    Last Post: November 28th, 2007, 04:22 AM
  3. Need help with a few codes.
    By slopokegtp in forum Gen III V8 Specific
    Last Post: July 27th, 2007, 12:36 PM
  4. abs codes
    By slimdad920 in forum General
    Last Post: July 9th, 2006, 01:34 PM
  5. o2 codes
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2005, 07:20 PM
