Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Question on tuning LARGE INJECTORS
    Apr 2005
    Default Question on tuning LARGE INJECTORS
    I have 60lb/hr Mototron injectors and I am having difficulty tuning below 40KP of manifold pressure. During AutoVE it always tells me to subtract like 20-25% of the table below 40KP and everytime I am off the throttle my engine runs WAY rich (10-11:1), I remember reading on here that I can play with the Pulse Width in that area in the V vs RPM table but I have also read not to.
    Could anyone shed some light on this for me?
    Jan 2005
    Click the reference material link in my sig, then "tuning for big injectors" - lot's of good info and might be all you need. If that doesn't work, post back here.
    Apr 2005
    Well I am going through your list of things to do and I am having small amounts of luck but no major progress. It does feel like I have cleaned up the idle a tad but I still get overly rich on decel.
    Does anyone know if my injectors are plate style or pintle??? Also... Does anyone know what is the minimum pulse width I should command with these?
    Thanks again!
    Apr 2005
    Well I did find some info on these injectors...
    On time is 1.14ms and off time is .85ms. So I gues I should change my default Minimum Injector Pulse Width to 1.14???? I am still confused though on what I should set my Low Pulse Threshold to though... Any ideas?
    Also... I started upping the flow rates under 35KPA and that did make a bit of difference. No where near right yet but getting there. I think I went a little too far the first time though because I went to start it and I got nothing but cranking!
    Jan 2005
    What's your fuel pressure?
    Apr 2005
    Stock at 58 PSI, I guess it would help if I had a set pressure of 43 PSI since thats what these were rated at. The fuel system is stock except for a walbro pump and the injectors.
    Anyone know if they make a LS1 style fuel pressure regulator set for a loer pressure that I could swap into the gas tank????
    Jun 2005
    Quote Originally Posted by RacerChris View Post
    The actual minimum on/off times of the injector are the min pulse width PLUS the battery voltage offset PLUS the short pulse adder. With my stock internals LS1, I need a pulse width of 1.6~1.7ms for a stoich idle with my Motron 60s. I had to play with the voltage offset table and zero out the small pulse adder to get the idle AFR to a reasonable level.
    Apr 2005
    Quote Originally Posted by SSpdDmon View Post
    I will be sure to adjust this tonight and try a few logs. I will report back tomorrow.
    Thanks again
    Senior Member exploder's Avatar
    Aug 2008
    I have 96lb low impedence injectors in mine....here is my tune file and I have them running good at idle.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
    Apr 2005
    Quote Originally Posted by exploder View Post
    Thanks for sharing your tune, I dont believe it will do much good though because our injectors will have completely different personalities.
    However, after looking at your tune I noticed that your VE tables were pretty spiky, are you finished tuning it??? If so you may want to take another go at it and do some smoothing.
  1. help tuning injectors
    By pdasterly in forum Gen III V8 Specific
    Last Post: June 14th, 2015, 12:51 PM
  2. Tuning Bigger Injectors Help
    By BrianC98Z28 in forum Gen III V8 Specific
    Last Post: February 10th, 2008, 03:40 AM
  3. Tuning cammed LS1's with large injectors?
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2007, 11:41 AM
  4. looking for big help with tuning an extremely large cam in my ls1
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 21st, 2006, 07:52 AM
  5. looking for big help with tuning an extremely large cam in my ls1
    By 01blkss in forum Custom Operating Systems
    Last Post: May 11th, 2006, 06:07 AM
