Results 1 to 4 of 4
Thread: cos3 to cos5
    Oct 2008
    Default cos3 to cos5
    can I program 02020005 into my ECM and then do a calibration only reflash from COS3 to get started? Or, I have a good working COS5 tune from another car. Can I do a full reflash using this file after I have modified it with my fuel map and commanded AFR?
    Last, is there a tutorial just for COx to COS5?
    thanks.
    wingnut, welcome to the forum...
    You should be able to.
    Or you could open 02020005 as the calibration and 02020003 as the alternate, and then do (in this order):
    - copy all the non-engine segments,
    - click on the Show Differences, highlight all the differences, click Update,
    - check for out-of-range values (check also in the custom segment) and fix them,
    - save file,
    - do full flash,
    - read flash to new file and compare.
    Oct 2008
    wow. thanks!
    I mainly need this system for the Juice, but i am going to use the alpha N for just my idle segments. 50 60 on map and 800 to 1200 RPM. Everything else is dead on.
    thanks again.
    Oct 2008
    It worked Joe! Thanks.
  1. cos3 or cos5
    By aaronr in forum Custom Operating Systems
    Last Post: March 15th, 2009, 03:09 PM
  2. Help with cos3
    By EVODRIFTER in forum Custom Operating Systems
    Last Post: November 2nd, 2008, 03:50 PM
  3. COS3 or COS5?
    By 00RAPTOR in forum General (Petrol, Gas, Ethanol)
    Last Post: December 6th, 2007, 04:36 AM
  4. COS3 and COS5 lean cruise PE Mode AFR error
    By ringram in forum Custom Operating Systems
    Last Post: August 16th, 2007, 07:25 PM
  5. V2 Cos3
    By Chevy366 in forum FlashScan V2
    Last Post: April 20th, 2007, 10:12 AM
