Come on by.
Come on by.
Custom Tuning Services
When you want me to drop by?
BTW: I really appreciate it.
-Nemo
2004.5 LLY Duramax, Compounds, EFILive, EvolvedMS.com 50" Trac Bars, DDP Injectors, PPE Pump, 4" turbo back exhaust, 6" Chrome Stack,
ATS Trans w/ Triple Loc.
Evolved M.S, LLC & SS Diesel Tuning
anytime this week will be fine. Except Monday.
how did it go Nemo?
After you put that one in I have not changed...its pretty fast, trans holds and im getting about 21-23 mpg... I will attempt to tune it myself on Friday night if my Fuel pump gets here in time...
So basically we unhooked the stereo fuse, the aftermarket amp, and the problem is my Volts drop when the tune starts going in, so I will be changing my batteries soon. If that does not fix it I will move to a bigger alternator.
If im missing anything Killerbee please correct me...
-Nemo
What is your voltage during a tune install? Load test your batts before buying a new alt.
12 Second LMM
we didn't take a reading on the bus, but his gauge was unusually low. After pulling his aftermarket amp fuse and throwing a battery pack on it, it flashed fine. That all happened after several failures, so my conclusion was voltage. We got lucky.
