I run 96 lb/hr injectors with a acceleronics injector driver. I run no boost reference for the regulator and I run a steady 45 psi fuel pressure. I scaled the injector flow rate to about 12 to 13 following a scaling chart from ls1tech. My question is that # goes up on the map along with Map Kpa. Why does it change? I do not run a boost reference for my regulator so should the flow rate #'s be the same for the whole chart?
Is 45 psi correct with the 96 lb injecotrs with a return system?
Because I run 3 bar, do I rescale the injector flow chart for boost?
How is this setup to work, and how should I have it?
