Results 1 to 7 of 7
Thread: Error Message while change tire size
    Sep 2008
    Default Error Message while change tire size
    I have 02 Chevy trailblazer I6 regular. I have 3.42 gear ratios change tires from 245/65/17 to 265/35/22.
    While changing my tire size i recieved an error message "Access Violations at adress 005CC926 in module ' EFILIVE_Tune.exe'. Write of address 0000053C. What does this all mean??
    Jun 2005
    Can't really tell ya but sure don't sound good.
    Roy 98SSSSSS
    Which build (Help->About) of EFILive software...?
    Sep 2008
    the latest 7.5.5 (72 built)
    First run the updater to get 7.5.5 build 74, but what OS are you running on you machine? Vista causes weird issues with EFILive, need to go change the properties of the EFILive_Tune.exe file so your user account has full access.
    Sep 2008
    yes i have vista. i just change it to 74.
    But some how the firwire program wont upgrade to build 72. it is still on build 40. how do you upgrade the firwire program?
    and what exactly do i have to do change the properties on the efilive_tune.exe?
    To upgrade your FlashScan V2 firmware:
    1. Install EFILive V8.1.
    2. Read the document Start->All Programs->EFILive-V8->Documents->Upgrading Firmware.
    To change permissions on the EFILive_Tune.exe:
    1. Run Windows Explorer (Press Windows Key+E)
    2. Locate the EFILive_Tune.exe file in the folder: C:\Program Files\EFILive\V7.5
    3. Right click on EFILive_Tune.exe and select Properties.
    4. Select the [Compatibility] tab page.
    5. Check the "Run this program as an administrator" check box.
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. Tire size change oddity and other weird issues
    By pjaneiro in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 6th, 2009, 10:01 AM
  3. Adjust for tire size
    By Boost in forum General (Diesel)
    Last Post: March 29th, 2007, 11:32 PM
  4. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
  5. Tire size change calulation
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 08:52 AM
