Results 1 to 9 of 9
Thread: V4 License auto or manual
    Nov 2008
    Default V4 License auto or manual
    Just need to check if this was auto or manual as I wanted to get up and running. Order says pending....
    Oct 2004
    Only PCM and VIN licenses for FlashScan V1 and V2 respectively are automatically fulfilled. Other orders are generally turned around in 24 hours. It is Sunday night here now, so will likely be tomorrow morning local time.
    Andrew
    EFILive Crew
    Nov 2008
    Default Ok
    Thanks for that -
    Just a bit hot to go - in Darwin sweating it out.
    Ed.
    Your V4 license has been sent.
    Nov 2008
    I have the license but a lot of the dtc codes etc are missing and or the scale factors in the xml for lanos/daewoo are incorrect or missing. This didn't show up in the eval copy due to the limit on diplayed items.
    How do I get a correct xml for my vehicle ?
    While this is an old product it is still quite expensive and I would expect to have some more functionality out of it than is present.
    EFILive does not supply/support the xml files for the Daewoo vehicles. The xml files for the Daewoo vehicles have been supplied by customers who built their own data stream definitions for the listed Daewoo vehicles.
    You could try contact the authors of those *.xml files. Or maybe search around on the internet for information that you would need to build/update the Daewoo data streams. EFILive V4 is designed so that end users can create/update/add thier own data stream definitions.
    I understand that you may have been expecting complete support for daewoo vehicles "out of the box". Unfortunately that is not the case. If you think you have not received the product you were expecting (and paying for), we can offer you a full refund.
    Nov 2008
    Hi,
    yes, I was expecting a bit more out of the box support for the Daewoo.
    But, can you give me until Monday to decide?
    I have dug up some information on the car and will see if I can input that into the program and create a better xml for the car. If I can, I will keep the software, If I cant - then I will take you up on the offer of a refund.
    Ed.
    Nov 2008
    Default Going to take you up on the refund
    I am afraid the lanos/daewoo/lanos2 xmls are way out of wack for this car.
    I cant use this product for the car.
    How to I go about arranging to return/refund. V4
    Ed.
    Send an email to me paul@efilive.com with your original order number and the last 4 digits (and only the last 4 digits) of the credit card used to make the purchase.
  1. auto to manual e38
    By dags in forum Gen IV V8 Specific
    Last Post: March 6th, 2010, 09:18 AM
  2. Conversion of Auto to manual.
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2009, 09:58 AM
  3. auto calibrations for manual?
    By BackinBlack02SS in forum Gen III V8 Specific
    Last Post: December 2nd, 2008, 02:08 PM
  4. camaro auto to manual conversion
    Last Post: March 26th, 2007, 12:15 AM
  5. How to change an auto calibration to a manual one?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:12 PM
