Results 1 to 3 of 3
Thread: TPS Perfomance fault
    Aug 2007
    Default TPS Perfomance fault
    Any ideas on what would cause a intermittant TPS performance fault other than a TPS? I have replaced the TPS, checked the loom with a wiggle test and replaced the ECU (as part of the tuning due to a locked ECU) the problem was present before and after tuning. Causes Trac control to fail and trans to shift hard, seems to fault when hot idle in gear, turn the car off and restar and problem is gone for a while. Tps reads live data in the scan tool OK.
    Joel
    Lifetime Member macca_779's Avatar
    Jan 2007
    Does the car run a largish cam. I have seen this before in the past and you just have to open up the performance limits to prevent the fail from coming up. Refer C3907
    Aug 2007
    Yes thanks Macca, I did work it out, had to raise the perfomance test limits such that 0.0 % throttle was OK for 800 rpm.
    Joel
  1. Long term memory perfomance ECM
    By sweetdiesel in forum Duramax LB7
    Last Post: July 23rd, 2009, 02:55 AM
  2. Fault
    By GMLSI in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2007, 04:56 AM
  3. OL-Fault
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 11:07 PM
  4. CL-Fault ?
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2006, 08:34 AM
  5. OL-Fault?
    Last Post: April 23rd, 2005, 04:43 AM
