Results 1 to 3 of 3
Thread: 3bar custom OS questions
    Oct 2003
    Default 3bar custom OS questions
    I'm about to install the custom OS and have a few questions. The tutorial has a section about running in semi open loop. It says to disable closed loop and LTFT and then it states:
    Several other STFT values may require adjustment:
    • {B4101} Closed Loop Idle Vehicle Speed
    • {B4102} Closed Loop Idle Vehicle Speed Hyst
    • {B4103} Closed Loop Idle Throttle Position
    • {B4104} Closed Loop Idle Throttle Position Hyst
    • {B4108} STFT Idle Enable
    In what way should these be adjusted? Would I want them similar to stock (enabled) or disabled.
    [/quote]
    Oct 2004
    Check out http://www.efilive.com/forum/viewtop...r=asc&start=15.
    I understand that you want it disabled. I asked the same question (below), and Ross confirmed. Doesn't get any better than that.
    I think you may need to actually set the values to the min. Reading the descriptions it says that the speed must be below the value for closed-loop fuelling to occur. This is assuming you wanted to disable closed-loop fuelling?
    Is this right Ross?
    I set {B4101}, {B4102}, {B4103}, {B4104} to 0 & {B4108} to Disabled. Is that correct?
    Andrew
    EFILive Crew
    Member bK's Avatar
    Mar 2004
    Quote Originally Posted by Tordne
    I think that has moved here. http://forum.efilive.com/showthread.php?t=832
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
  1. Questions and some advise about custom OSv3
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 10:45 PM
  2. Custom OS questions from a new tuner
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 02:00 AM
  3. two 3 bar custom OS questions.
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 16th, 2005, 09:45 AM
  4. Questions about swaping from 99 OS to custom 01 OS
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 09:49 AM
  5. Custom OS 3bar problem (need the experts)
    Last Post: September 12th, 2005, 04:10 AM
