I rescaled the 3 bar map parameter to 287 witch matches the stock map 1 bar reading. As soon as I hot 1 psi the map gauge on the dash is maxed and it falls on its face. Map gauge idles at about 100 kpa?? What would cause this?
With a 2002 custom O.S. for 3 bar should the MAF FREQUENCY FAIL 1 (2901) BE 0 OR 1, AND SHOULD MAF FAIL FREQUENCY FAIL LIMIT (2903) BE 0 OR 1? I am finding conflicting posts? I had the "fail 1" set to 1, then I saw a pst that said to put it to 0, so I did, I think I will put it back to " 1" and see if it still does that.
Anyone?
