Results 1 to 8 of 8
Thread: can read but cant flash ecm
    May 2007
    Default can read but cant flash ecm
    I updated to 7.5.5 and now when I try to flash a tune in my nova it says conection lost . check all conections.
    then I do it and it goes through real fast and then say's battery power to high or to low.
    I connected my v2 to the obd2 port and tried to go to pids and it gave me an error saying no Options txt.
    I went into efi explorer and configured files where I copied the top section and pasted into the lower section. Now it seems to be working right but not sure.
    I updated my firmware but not boot blocker. what is the latest release for bootblocker?
    The car I am trying to read and flash is my project car.1964 chevyII Nova with a ls1.
    I can read my trans am tune fine, I then went and read my Nova fine. When I try to flash my Nova It gives me the connection lost or like I said earlier, it runs through real fast and says complete but the green bar and time never shows that it went through. It also has a section in red that says battery to high or to low.
    Any pointers?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    Hi Aint Skeered,
    What firmware and bootblock is in your V2 (open EFILive Explorer (EE), goto firmware tab)...?
    You need to copy the Options.txt file to the V2 Config tab using EE... Options.txt is new and replaces Options.ini... if you had any particular pids you were logging, you have to copy/replace them into the new file (be careful to not disturb other stuff in the new file, and keep your pid channel count at 24 or less, i.e. no more than 4 packets).
    Which PCM are you using in your '64 Nova...?
    May 2007
    Joe I plugged in this moring before coming to work and the bootblock was back from april but in efi explorer I went to look at the firmware and it was from april of 08. (cant recall the number) but I opened efi control panel and updated my v2 to bootblock 2.06.02
    and firmware to 2.06.05
    It will be a week before I can plug into the car to see if it helped. is this what is supposed to be there?
    2000 NBM trans am.
    Current versions:
    Bootblock 2.06.02
    Firmware 2.06.05
    So you do have the current versions.
    Post your Options.ini file.
    What PCM and OS are you running with on your Nova...?
    May 2007
    I am back on a tow boat now. I am running 02 z28 op system in a truck pcm i believe.
    I have reason to believe my pcm is bad, we are getting spark and getting fuel to the rails but not through the injectors. I changed injectors last night and still not getting fuel. When I get back home I am going to get a noid light to check the injector pulse. Is there a way to do that with efi while cranking?
    My boot block was not up to date last night when I tried to flash it so this may have fixxed it when I updated this morning.
    2000 NBM trans am.
    May 2007
    when i get home next tuesday, I will see if it works . If it dont I will post the options .ini file and pm you to let you know I did so. Thanks, Chad.
    2000 NBM trans am.
    Is VATS kicking in and cutting fuel...?
    May 2007
    I set anti theft to none. Is there something else to turn off?
    2000 NBM trans am.
  1. I can't read a tune, but can flash one
    By dlove in forum FlashScan V2
    Last Post: October 2nd, 2009, 10:19 PM
  2. P10 high speed read/flash issue
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: September 17th, 2009, 09:15 AM
  3. pull fuses on lb7 to read/flash ???
    By justin123 in forum Duramax LB7
    Last Post: April 15th, 2009, 10:29 AM
  4. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 01:00 PM
