This is used on 2000 to 2003 It uses 2 Infineon processors. The first is a SAK - C167CR - LM GA The second is a SAK - C167CR - 4RM The C167CR/SR are high-end members of the Infineon full featured single-chip 16-bit microcontrollers. High CPU performance is combined with peripheral functionality and enhanced I/O-capabilities. A wide variety of on-chip features such as large on-chip ROM, multi-functional standard peripherals, and application-specific peripherals (e.g. optional CAN) is available. The C167CR features an on-chip CAN module which has been designed to fulfill the requirements of automotive and industrial control applications. http://datasheet.digchip.com/216/216...67CR-4R33M.pdf
This is a P07
Hey guys
This is the 04 to 05 Northstar FWD PCM
This is known as a P07 PCM
AM29F200BB
-55SE
0339ABA J
1997 AMD
AM29F800BB
-55SE
0343FBA HH
1996 AMD
The two processors are
Infineon
SAK-C167CS-LM
BOSCH
BA SIEMENS 97
__________________________________________________ ___
This is a P07 and a E22 side by side
FWD Northstar vs a RWD Northstar for 2004 and 2005
stored backwards is what I ws thinking.
Every 2000 and 2001 FWD Northstar uses 2 segments. The large segment is 421 kb and common in all 2000 and 2001. The VIN specific/Build is all in a smaller file. 76 kb
Every 2002 and 2003 uses one large file again, but it has a different cal ID. The small file is 76 kb again.
76 kb and I can't get a VDF built. I am spending tooooooooo much time looking at over 100 different cals and determining what = what
I scanned a 2004 FWD Caddy. I built it as a 2003 and I had proper communication. I had a 2000 that I built as a 2004 and I had proper communication. If the protocol is incorrect the Tech II will state Wrong Vehicle Selected. This git me thinking. Same CPU in both Hmmmmm. I wonder if I could install the P07 in a 2005 RWD Caddy and get the Tech II to communicate with the PCM over GMLAN.
I had no communication on the GMLAN
I filled the intake with gas and had to clean that mess up.
I am about ready to by software for the 2006 and up Northstar's. Then I will work backwards to get the 2004 and 2005 RWD Northstar's hammered out and then into the 2000 to 2003 to get those done. I am just missing too much. I had a friend help me with the big file and he found one line. I think it was injector rate vs voltage. I sent him the wrong file. I should have sent the smaller one.
Keep hacking guys, thats what we like to see
When you get bored you can start on the dodge ECU's
2014 VF SV LS3 Maloo.
I had heard Dodge had that rolling encryption making tuning hard, I also heard that another tuning shop had used TunerCat OBD1 to make a def file it and was using that to tune them, but not sure what they used to flash unless they did it the old fashioned way, with my heat gun.... Has a great effect of rendering any "password" or S/K useless.... Like Ross said, like having your keys and being already inside the car.....
