Paul will be working with me this week, we are going to try to figure out why H0101 is so wrong on some calibrations. It is not a scaling issue, the scaling doesn't change, it's like in some calibrations don't actually use H0101!
Hi Ross,
yesterday I tried a different TCM .tun file. The value of H0101 looks better ( I mean within a reasonable range) but when I try to correct for tire size and revs per mile and try to save that .tun file I recieve a range error every time.
I played around a little and it seems as soon as I touch the speedo calibrations and try to save that file I will recieve a range error.
Also when I type in the value for the revs/mile,, as soon as I touch the original value a warning message appears that a tire with such a big circumference doesn't exist or something like that.....that message is ok but only after I typed in a wrong value and closed that with return?
Next I took a ECM .tun file and did the speed calibrations. No problems at all, everything works as expected.
By the way I am using the latest EFIlive software ( built 72)
Thanks for helping
Harald
If nobody has done it before, somebody has to do it....
1997 Tahoe 2dr 4WD
2002 Alfa Romeo Sportswagon 2.0 JTD
1982 Deutz Intrac 2004A
2003 friesian Horse " Henry"
Upgrade to the latest build, 75. Have to use the new update function in the start menu, works pretty dang slick if I do say so myself.
Hi, I easily updated to built 75 but that speedo correction stuff is still a little mixed up
1997 Tahoe 2dr 4WD
