Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: e38 cranking help
  1. #11
    Oct 2005
    Quote Originally Posted by hymey View Post
    I had similiar issues with 230 cams, I had to command a lot more min idle airflow then stock. It was worse when hot. Increasing cranking air and min idle air cranking timing. and B1845 multilply that by -50% reduces hunting a lot. I would imagine being a big cube engine it would need a lot more air.
    Yep pretty much exactly what Ive done. She eats shedloads of air
    Im still progressing ok, so will post up if/when I get stuck
    2014 VF SV LS3 Maloo.
  2. #12
    Jul 2007
    Quote Originally Posted by swingtan View Post
    Hi Ringram,
    I was talking to someone about this sort of thing last week.
    Have a look at B8062 and "REDUCE" the % value for the cranking. I haven't put a lot of thought into why this works, but it seems to help a lot with larger cams. I think the guy I was talking to tried values around 75% to start with, and then jumped to 50%.
    The other table would be B5119. For some reason, GM decided to put some weired steps in the spark map for cranking. I removed the -VE values, added some timing as the RPM rose and smoothed the lot out.
    Hopefully this helps a bit.
    Simon
    After going around and round in circles changing cranking idle air and timing, i tried this, i reduced B8062 cranking ve to 75% and now have perfect starting!
    Safe to say i'm a very happy man now, i was getting sick of putting my foot on the throttle to start the car
  1. 7.4L- 0411ecm - WAY! TOO RICH AT CRANKING
    By stroker97k1500 in forum Vortec V6/V8 Specific
    Last Post: December 7th, 2009, 05:26 PM
  2. Injection Timing During Cranking
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 7th, 2007, 03:48 AM
  3. Cranking Injection Qty Map
    Last Post: April 3rd, 2007, 08:54 AM
  4. PID for Engine Cranking?
    By TAQuickness in forum General
    Last Post: March 11th, 2006, 01:16 AM
