It is connected, updating in real time selected, course control, scanner running, and it shows the cell logging. The RR is the correct firmware version, 12.14r and shows to be working just doesn't update the file. I'm trying to do a TPS VE table, and it highlights all the cells it hits, but doesn't change anything. I wasn't sure if it would show the changes on the tune file during emulation, so I pulled the file out afterwards and did a file compare and there was no changes from the base tune I was working with. Thanks in advance!
John
