Results 1 to 3 of 3
Thread: r.p.m. limits
    Oct 2008
    Default r.p.m. limits
    Hello, I was wondering is it possible with the dsp5 to pick a position, say level 2, and limit the rpm's to 2000? The reason I ask is I read on here or diesel place that if you stay below 2000 rpm's that it keeps the main pilot? from opening up and that is where you really see a big fuel consumption increase. So what I am wanting to do is program level 2 to not go above 2000 rpm's which would give me about 68 mph. Thanks for any help.
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Assuming you have an LLY you need to adjust the rev limiter tables B0725 and B0726. Not sure if the rev limiter tables themselves would take care of that completely, so I would cut back on the fueling tables above 2k to make sure.
    07 El Bee Zee
    Little faster than stock...
  1. VVT control - limits- tuning - etc.
    By scdyne in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2010, 03:58 PM
  2. LLY MAF table limits
    By Cougar281 in forum Duramax LLY
    Last Post: June 30th, 2010, 10:55 AM
  3. Barometric TQ limits (LMM)
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 21st, 2009, 01:15 AM
  4. Speedo pulse limits
    By VHR in forum Gen III V8 Specific
    Last Post: September 19th, 2007, 04:41 PM
