Results 1 to 10 of 11
Thread: Speed Density
    Oct 2007
    Default Speed Density
    Can anybody tell me what is required to do a speed density tune on a VZ L76 motor other than a license..custom operating system?......if not are the both octane table active when the maf is disconnected etc?
    Yortt
    Oct 2005
    Read the AutoVE tutorial mate, it covers going into SD and tuning the VE table etc.
    2014 VF SV LS3 Maloo.
    Oct 2007
    Quote Originally Posted by ringram View Post
    Thanks for the reply, I have read the AutoVE tutorial, maybe you could tell me what custom operating system I use for this 2006 VZ L76 6 litre engine operating system 12607218 to run speed density?
    Lifetime Member macca_779's Avatar
    Jan 2007
    Don't need a custom OS mate as the car runs an E38 Controller.
    Have a read of swingtans tutorial. It covers what you need.
    http://forum.efilive.com/attachment....8&d=1227069891
    Oct 2007
    Default Speed density
    Quote Originally Posted by macca_779 View Post
    Thanks macca, this confirms what I thought was the case, good tutorial by swingtans saves me finding the appropriate wire.
    The only thing I need to confirm now is, is the hi and low octane ignition tables still active? from what I understand they are still active when the MAF is unplugged unlike the LS1.
    Jan 2007
    Yeah mate they are both active when you fail the MAF on an E38
    The only thing you will loose when going SD on an E38 is the traction control / stability control will not work. But, to fix that you will see a section called Operating System patches, you need to apply both TCS patches and then all that will be functional when in SD.
    Oct 2007
    I did pick that up from the forum and help file, thanks for the clarification anyway.
    Yortt
    Oct 2007
    Default License
    Another question do I require one license to tune this vehicle or two ie one for the engine and one for the transmission?
    You have to have a V2 to read/tune this car and it uses 1 VIN license (aka you can tune 1 ECM and 1 TCM).
  1. Do I need the Speed Density COS?
    By MisterGuru in forum Custom Operating Systems
    Last Post: June 4th, 2009, 11:41 AM
  2. Speed density run.
    By nissmo in forum Custom Operating Systems
    Last Post: October 30th, 2008, 03:05 PM
  3. speed density
    By mikesp1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 31st, 2007, 05:29 PM
  4. speed density
    Last Post: January 14th, 2006, 06:13 PM
  5. Speed density
    By Drake in forum Tutorials
    Last Post: February 22nd, 2005, 03:01 PM
