Originally Posted by
avoturbo
HI all,
Setting up a TT LS1 and had the car starting and idling beautifully on Sat morning, get in this morning and injector duty whilst cranking is hard on 56%, this seems to be related to the map sensor somehow as the engine was SO flooded that no vacuum reading was obtainable, yet if the map sensor is given vacuum manually then the cranking IDC drops back to where it should be.
Anyone have any ideas?
My friend with a LARGE single on his LS1 says:
put the fuel maps back
manifold vaccum during cranking does not change for forced induction
I have a feeling he threw the maf or the ifr table way off rich maybe trying to get the fuel trims right on whatever injectors he's running
or maybe he mucked with the fuel system and has way too much fuel pressure
theres no reason it should crank up any different power adder or no
