Hey i have a 2002 Z06 with a large cam and exhaust. When you crank the vehicle the rpm jumps up to about 2000 rpm then falls to about 500 rpm and almost dies. It will then surge a couple of times then stabailize a 1000 rpm which is where the base idle is set at. what can i adjust to stabilize the idle, ive been racking my brain. It also sets bank 1 and 2 lean codes but runs a 12.8: 1 when on the throttle and about 14.8 to 15.2 a/f when crusing. and should i disable the rear o2 sensors before tuning. any suggestions would be greatly appreciated.
