Results 1 to 10 of 11
Thread: Tuning a trans
    Dec 2008
    Default Tuning a trans
    Iam new to tuning ...i was looking up post on tuning trans and iam getting confused... can some one help me with my tune file...My mods are Headers, true duals, 4l60e w/ 3600 vig Tc and a Moser 9 inch w/ 3.70's ..thanks
    What rpm do you want to shift at...?
    Dec 2008
    Thanks joe..iam still new to this scene...What would be good for a street car? I DD the car and Drag race it
    What valvetrain does your motor have...?
    If it has the stock valve springs, rockers, pushrods, lifters, than most people would recommends the stock WOT 6000 RPM.
    If you have valvetrain components, then you could shift higher, 6500 maybe.
    Is your 4L60E stock...?
    How many miles on it...?
    How does each upshift feel (at part throttle and at WOT)...?
    Do this:
    - set the Shift Times tables to 0.2 or 0.3 flat across;
    - increase the Shift Pressure tables (aim for 90-96 psi at the upper end of your torque range, and make a straight sloped line from zero to the upper end);
    - reduce the Torque reduction tables to half (and go test drive for feel; fine tune this to suit how you want it to feel -> firm positive shift [without being harsh] is good);
    Also do this:
    - reduce the WOT upshift MPH settings by 10-15 MPH (allows the WOT RPM to rule),
    - make each of the WOT downshift MPH settings about 10 MPH less than their corresponding WOT upshift MPH.
    If you don't get any tranmission DTC's then you should be good.
    Post some logs.
    Dec 2008
    Yeah stock 4l60e and stock valvetrain
    46000 miles
    Feels loose
    Dec 2008
    thank you sir..ill post logs when i get a chance
    Here's your file with pressures/times/TR edited for more feel.
    Dec 2008
    heres a log...I Tried to get some wot runs in...on some side streets due to traffic... a dtc code came up on the last run...p0113 high voltage thru the ait sensor...then it felt the car went on limp mode with the trans
    Dec 2008
    Default new log file
    Heres a new log file
    I'm out of town till Wednesday, I'll look at it then.
  1. trans tuning for the allison
    By Dmaxvaz in forum Diesel
    Last Post: February 16th, 2011, 06:57 AM
  2. Need trans tuning help
    By Gregs in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 1st, 2010, 04:09 PM
  3. Need help with trans tuning..
    By BowlingSS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2010, 01:58 PM
  4. Tuning trans pressures
    By charcold-bowtie in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 4th, 2009, 05:49 AM
  5. E38 Trans Tuning
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 03:38 AM
