Results 1 to 8 of 8
Thread: HELP!!! AFM won't enable....
    Aug 2008
    Default HELP!!! AFM won't enable....
    2008 Silverado (E38) (T42) 6.0ltr/4L70E (L76) OS-12617631-
    I disabled my AFM so I could check my MPG without the help of AFM and I saw what I needed, I re-flashed the ECM to enable AFM and it won't work even with a full Flash....Do I need a different(new) ECM? Any Ideas?
    Maybe there's a AFM fuse?
    I've tried disconnecting the battery and re-flashing like 5 times(2 Full Flashes)
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    If EFI Live disabled AFM it should enable it right?.....
    Certainly, if all you did was to Enable / Disable the AFM using the option (I'm assuming) then there is no technical reason it should not come back to life when re-enabled.
    Did you try flashing a file back from before you turned it off (like an older tune).
    Aug 2008
    No Ross,
    Thats the one thing I haven't done! I will try flashing an older tune file Tomorrow morning.....
    Aug 2008
    Well, I tried flashing in an older Tune file and No Luck...AFM still will not enable
    Member nycblazer's Avatar
    Jan 2008
    did you get it fixed? let us know
    Aug 2008
    Yes, I got it to work...I had disabled the COT protection because of overly rich AFR condition at WOT and apparently AFM won't enable if COT is disabled...So i re-enable COT and it's been working ever since
    Thanks for letting us all know, I would never have thought of that.
  1. HOW TO....enable GM.ENGOILP
    Last Post: December 15th, 2009, 02:47 PM
  2. egr enable
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2009, 07:01 PM
  3. DSP2 enable
    By Kennedy Diesel in forum Duramax LB7
    Last Post: July 2nd, 2006, 01:39 AM
  4. How Do I Enable IAT with MAF Disabled?
    Last Post: May 14th, 2006, 07:34 AM
  5. What rpm to enable LTFT?
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 06:56 PM
