Hi guys,
Just wondering if anyone has seen this, I have both timing tables the same, no knock (or minimal knock) and the timing jumps around under boost. Sometimes 5-7 degrees which is enough to feel it in the car.
I have gone threw every table imaginable in the spark area, yet timing will drop. I will have it set at say 12 degrees and sometimes I might see it go as low as 5-7 degrees without knock or high IAT's.
Any suggestions?
Thanks in advance.
