Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: GEN IV swap AFM is not enabled
    Apr 2008
    Default GEN IV swap AFM is not enabled
    I am comming to the finish line with the 5.3 LMG swap into my 1997 Tahoe.
    One last thing is, I do not get all the conditions that AFM is enabling.
    After going through all the necessary conditions it seems that one thing that could inhibit V4 mode is the vacuum brake booster pressure sensor. It is read by the EBCM and then distributed via the CAN bus. So here's the problem, there is no easy way to get that sensor status on the CAN bus without an EBCM.
    Are there any possibilities EFIlive could disable some modules / conditions so that my E38 ECM is able to switch to V4 mode?
    Any suggestions?
    Harald
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
    Nov 2008
    I'm up against the same wall I believe I met all the conditions to enable AFM also; except the Brake booster sensor(82' Toyota 4 x 4).
    You are correct, the sensor data is sent via serial data to the ECM from the EBCM. The brake booster pid always reads 0 volts on the scan tool otherwise.
    My engine is from a 07' Siverado and there are two different EBCM's, one with JL4 and one without. The one without does not have the brake booster sensor but still has an E38. So I'm thinking trucks with AFM have JL4?
    I can't find any condition to change in the ECM calibration regarding the brake booster sensor.
    Sorry this doesn't help, I'm thinking out loud. It must be pass thru data from the EBCM the ECM reacts too, so maybe a OS patch is the solution.
    Maybe I'm thinking too hard and there is a simple solution Seems to me I've read about conversions where AFM works without the EBCM.
    Apr 2008
    Default welcome to the club....
    Now we are three with the same problem. Patrick is at the same point with his 5.3 LMG swap.
    If there are two different E38 calibrations out there ( with and without bosster sensor..) we should check if a suitable version of the E38 software calibration without bosster pressure sensor exists. As far as I know all '07 5.3's had AFM, so this is not the point.
    Harald
    1997 Tahoe 2dr 4WD
    Aug 2008
    Hey guy's, I'm trying to figure out why my AFM won't enable after I disabled it to see what my MPG was without it!!! Maybe there's something else involved...Can't figure it out...The last thing to try is my stock ECM, which I replaced with my current ECM(for tuning purposes)
    FLASHSCAN V2 & AUTOCAL
    GAMEOVER, have you tried flashing in any of your previous tune files (from prior to where AFM was disabled)...?
    Aug 2008
    Yes, I tried it yesterday. Ross told me that it might work but still wouldn't work....
    Aug 2008
    Maybe it's not the ECM...
    Aug 2008
    I'm going to try my stock ECM this weekend and maybe that'll be the fix
    Oct 2008
    If you can find anyone near Michigan with this issue let me know, I can throw that frame on the bus for someone and see if it turns on. If so it wouldnt take too much to design an interface that simply grabs can hi/low and transmits the frame at the appropriate intervals.
    Chris White
    www.GTOShiftLight.com
    2006 Spice Red A4 GTO
    2009 3LZ Z06
    2012 Jeep SRT8
    2013 SRX Premium
    2013 XTS Platinum
    Nov 2008
    There are several 5.3's offered in the 07' Silverado Classics which do not have AFM. I see three brake systems offered and none have the booster sensor. It would be interesting the compare calibrations but since the Classics don't have AFM it's not promising.
    I think GTPprix is on the right track. If he could simulate the bus data, and AFM enables it would at least verify our suspicions.
    GAMEOVER make sure your COT is enabled, I heard disabling it will take out AFM
  1. pcm swap
    Last Post: August 18th, 2009, 07:10 AM
  2. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  3. 97-02 pcm swap ?
    By TurboVet in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 01:08 PM
  4. 01 to 03 ECM swap
    By sweetdiesel in forum General (Diesel)
    Last Post: January 3rd, 2008, 06:03 AM
  5. VIN swap
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 04:18 PM
