Ok had some starting issues,got those resolved no problem.I have a bad stumble if i stab it under about 1600 or so,it has a 256 at 50 cam 630 lift range,long tubes ported t body.
My fuel trims are within 1 to 2 percent to the rich side everywhere and wot is 12.8 20 degrees timing with no knock,but when you stab the throttle at low rpm it almost soounds like a lean pop threw the intake,but trims stay good along with a/f...Please help thanks.
And yes this is my first time with this ecu e38 thing.So far not a fan.This is my last issue with it as i will be turning it loose once i get this last little problem fixed.Thanks
