1. When I start the car up the car it idles a little leaner than I would like in the 16-17 range...as coolant temps rise the car gets better and better. I went to B3632 after start coolant temp enrich. I want to add more fuel in this area, but it says the number will subtract from the EQ ratio. So my question is do I make the numbers bigger here or smaller in the areas I want to modify.
2. When I go from P to D the idle jumps to from 850 to around 1500 rpm for a split second and then come back down almost immediately...kinda like it wants to lunge forward....I can't figure out which table to modify to combat this.
