Rusty,
First do what Blacky/Paul said in post #10...
if you can't get cal-only flash working, then there may be other PCM functions that are not working (it might explain 4 cylinders not firing).
Blacky,
Can I use a newer operating system with my PCM? I am concerned that my PCM is not normal. From my posted tun file is that possible. On the outside it reads "Grand Am Cup". It also reads something like "No spark, Must have separate controller"
If the operating system and hardware is just normal, then I really would like to program to US as the Metric defaults from Canada are a little hard to convert on the track. I currently just try to hit the dash button at 150mph, which can be a little distracting.
Thanks for your help.
The reason why I can not perform a tune flash and am required to perform a full flash is because the PCM serial number is all zeros. How can I get a Serial Number into the PCM?
Here is some data from EFI LIVE:
PCM
VIN 2G2FV22G2X2226801
Hardware Number N/A
Calibration ID 4294967295
Serial Number 000000000000
Operating System 09381344
Engine Calibration 16253254
Engine Diagnostics 16263887
Transmission Calibration 16264134
Transmission Diagnostics 16253323
Fuel System 16264551
System 16264738
Speedometer 9359157
Operating System BCC N/A
Yes, you can reflash it with an updated OS file. Make sure the OS file is for a 512KB PCM like yours and not a 1MB PCM. However, that won't help with the initial problem of "no serial number".
Have you tried full-flashing a totally stock OS file with a matching OS number like I suggested? If that does not fix your serial number then the PCM's memory is most likely damaged.
Also make sure you are using the latest version of our V7.5.5 software. You can download the latest version here: http://www.efilive.com/index.php?opt...=48&Itemid=124
Once you have installed the latest version (or if you already have it installed), select the start menu option: Start->All Programs->EFILive->V7.5->Tools->Check for New Update.
The note on the outside that says "no spark" is a concern. Is that just written on by hand or is it a factory sticker/warning?
As for the metric units, do you mean the dashboard in your car or the dashboard in the EFILive software?
I've run into quite a few situations lately where, after a TIS flash, the PCM will report a blank serial number, EFILive will update it. A subsequent "PCM Info" report will show a valid serial number, but any attempts to reflash the tune will show a blanked out serial. I can repeat this on just about any 99-00 OS.
I'll try and remember to grab one the next time I encounter this problem. I do what I can to avoid it (upgrade a customer to an 01-02 OS instead), but I'm sure I'll encounter it again.
