Results 1 to 10 of 14
Thread: DSP5 valet mode
    Default DSP5 valet mode
    ok, I have the switch wired up on pins #1 and #37 in the black connector. I have all 5 limp home tables set to 0mm3 from 1k rpm and up. I also have B0740 min. inj. qty set to 0mm3 from 1k rpm and up. Neither position of the switch will limit fuel.............what gives??
    I do NOT want it as a dsp table I want to use a different switch that I can hide. I do not want this for "valet" I want it for added anti-theft.
    The first time I tried it, I did not have the switch grounded in #37, I only had it to body ground and B0733 was the only one that would limit fuel and only if B0740 was lowered as well, BUT the switch did nothing, it was stuck in that limiting fuel mode. Now??? I don't get it. Am I missing something?
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Did you do a full reflash?
    07 El Bee Zee
    Little faster than stock...
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Being its already here, and it didn't have an answer, I figured I would revive an old thread to say that Im having the same issue with the Valet mode. High Idle works flawlessly, DSP works Flawlessly but when the Valet Mode is enabled in the tune{A0140}, it instantly reverts to Engine Protection Mode 1 {B0733} regardless. If you disable {A0140} (only change made to the tune) the truck runs fine, no engine protection mode. Here are the Segments and OS im using currently
    5875805 Operating System
    15904640 Engine Operation
    25779295 Engine
    15879109 Engine Diagnostics
    15879098 Fuel System
    15228743 System
    15233750 Speedometer
    Any input Ross?
    I don't expect a fix, just looking for input if this is a known issue or not and if not, just bringing it to your attention. Are there any work arounds?
    I am able to replicate the issue on this truck using 2 different ECMs.
    I'm gonna try a few other OS's to see if i can replicate the issue on those as well as different Segment combos.
    And i did verify that the pins are properly seated in the connector and making good contact.
    To add I have also rebuilt the DSP tune several times to ensure that it wasnt just a build error when it converted the base tune to a DSP5
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Neither the DSP-5 valet mode or DSP launch control on the 04-05 LLY actually works.
    Kinda frustrating, but I guess not enough people tested it back when LLY was fresh on the R&D table to point out to Ross that it is in fact broken on the LLY's.
    It works perfectly on LB7, but I was never able to get it to work on LLY, so I gave up on it years ago.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Dec 2012
    I knew the launch control never worked. But never tried the Valet till today. Well... That sucks I guess. Hopefully the E60 doesn't get retired before its fixed
    Josh
    '04 GMC LLY
    All news to me guys, but sadly it is unlikely it'll be fixed, too many miles travelled to turn back.
    Dec 2005
    aww.....it would be like a stroll down memory lane.
    Walk in the park, a mini vacation from trans Tuning.
    LOL
    www.mscservices.net
    Dec 2012
    I mean... Tony is.... right
    Josh
    '04 GMC LLY
    Nov 2005
    For the handful of people that have used the feature in the 9 years and 4 months since the documentation was first available in January 2007 the best all round solution may be to remove DSP2 from future software releases for LLY.
    Cheers
    Cindy
    Dec 2012
    Wait.... why remove DSP2? The only problem was with the Valet mode and DSP Staging thats included in the DSP5 COS
    Josh
    '04 GMC LLY
  1. E40 Valet mode?
    By ringram in forum Custom Operating Systems
    Last Post: April 27th, 2007, 10:21 PM
  2. Valet Mode
    By ZL1Killa in forum Custom Operating Systems
    Last Post: April 10th, 2006, 01:08 AM
  3. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
