When trying to select the PID's on the V2 It just flashes (very quickly....too quickly) Options text not found, and goes back to the main screen. What am I missing here?
Options.txt is located here: C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
Using EFILive Explorer (EE) copy Options.txt from that folder (upper pane) to the Config tab (lower pane)...
and also copy the .pmm file for your PCM/ECM.
The V2 should not be connected to the vehicle while doing that.
Try to format the config area with the EFILIVE explorer, then copy all the files in the top pane down to the bottom again.
What version of Firmware/bootloader are you running?
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
Bootblock 2.06.02, firmware 2.06.05
I did all the transfer off line. I was referring to selecting the vehicle for the PID's, does the vehicle need to be connected for that? I'll try reformatting and reselecting.
Edit: Reformatting seemed to take care of the selection issue! Thanks!!!!
I don't think I have ever tried selecting the PID list without the PCM connected. Give it a try with the PCM connected and see if it works.
I would try to confirm your issue, but I don't have a USB cable with me.
48 LB injectors
T70 turbo.
Everyone at work must be surfing the internet. That download is going slow
48 LB injectors
T70 turbo.
it was some what slow for me too.
but i had build (75) installed before this latest one (77).
LC-1 WBO2
