Results 1 to 10 of 15
Thread: larger high impedance injectors
    Oct 2008
    Default larger high impedance injectors
    i've been looking for some larger injectors, right now i'm running rc racings 750cc or 72lbs/hr @ 43psi. i'm running 60psi and don't want to run anymore fuel pressure. I know you can get a conversion controler to run low impedance injectors but was hoping that there was something around a 100lbs/hr that was still in a high impedance in a bosh stile top feel injector.
    thanks for any info.
    Member 427's Avatar
    Dec 2007
    Smile
    Quote Originally Posted by 496chevy View Post
    Dont think i have ever seen a high imp 100 pound injector-
    I believe the biggest high impedance (12Ω) injector is 72lb/hr.
    Apr 2007
    These are the biggest ones I know about.
    http://www.racetronix.com/01D129xFM.html
    They are very hard to tune at idle though, I don't think you can run under a 3.7mS pulse width.
    Update courtesy of MSURacing: 79lb/hr is the biggest 12Ω injector so far.
    Oct 2005
    They will be over 100lb with 4 bar surely?
    2014 VF SV LS3 Maloo.
    Apr 2007
    At 4 bar, 58psi, the 79 lb/hr's are a little over 91 lb/hr's.
    They really get hard to do a good idle cal with though, you are lucky if it will run at 11.5:1
    We're assuming the rating "standard" (if it can be called that) of 3 bar.
    Jul 2003
    Check the RX7 1984 or so... I believe it to be 100# and its high Z
    Highlander, do you have any links to those...?
  1. 7.4 Larger injectors, which ones..
    By Stamm1 in forum Vortec V6/V8 Specific
    Last Post: January 14th, 2017, 03:55 AM
  2. Racetronix 79 lb/hr high impedance injectors
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2009, 03:47 AM
  3. Update on my tune since swapping to larger injectors..
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: April 28th, 2008, 02:32 AM
  4. Impedance of Analog Inputs on V2
    By CGTMS in forum FlashScan V2
    Last Post: January 21st, 2007, 09:09 PM
  5. How To Tune For Larger Injectors
    By RacerChris in forum General (Petrol, Gas, Ethanol)
    Last Post: November 9th, 2005, 02:20 PM
