Results 1 to 5 of 5
Thread: Holden VE A6 Shift Patterns
    Feb 2006
    Default Holden VE A6 Shift Patterns
    Can anyone explain to me what each shift pattern refers to?
    There is Normal shift, Pattern A, B, TAP UP, TAP DOWN, Hot shift etc.
    Im guessing Normal Shift = Drive
    Pattern A = Drive + Sports Button
    Pattern B = Dunno
    Tap UP,DOWN = Manual
    Hot Shift = when trans overheats obviously.
    Any info would be much appreciated.
    Dec 2007
    Quote Originally Posted by Tre-Cool View Post
    Pattern B = Dunno
    This is close, based on scanned A6 parameters, but not with Holden control modes:
    Normal = Normal
    Pattern A = Driver Shift Control (TUTD) available
    Tap Up/Tap Down = Tap Up/Tap Down Active
    DSC available may or may not implement a change in shift pattern (depends on the cal), but when the TUTD control is used (tapped), it will switch into TUTD mode.
    Hot Shift - the trans attempts to cool itself down with a shift/mode strategy that is "proven" to create less heat.
    Hope this helps.
    Cheers and Merry Xmas.
    Feb 2006
    ah yes, makes a bit more sense now.
    so basically switching to manual mode, but not actually tapping the gears = pattern a or b.
    Pattern B = Drive + Tapup,Tapdown available
    Dec 2007
    Probably. Hard to tell exactly unless the various status states are logged/monitored. It varies by the TCM calibration options that have been set.
    Dec 2007
    Another note on the A6 and the physical selector positions which may add some context.
    P, R, N and D are as per most regular trans'. If the selector is in D, and there is no power on the trans, or a fault, or it has an unprogrammed controller, it may just drive around in 3rd gear and not change.
    The 6L80/90 has 3 more "D" positions. Call them D2, 3, 4.
    These positions are programmable in function and vary by calibration.
    Some cals do nothing into D2 etc, some like the Corvette shift to DSC ready in D2, some change to a "sports" shift pattern with higher shift points, some like the Holden/G8 drop the trans straight into first gear at D2 etc.....beware.....1st gear at 60mph would be a surprise, so fortunate that GM physically blocks the selector from other positions.
    Happy New Year to all!
  1. PE in HOLDEN VE L98
    By vessv73 in forum Gen IV V8 Specific
    Last Post: May 19th, 2009, 12:11 PM
  2. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  3. TCM shift patterns
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 17th, 2008, 07:05 PM
  4. Holden VE which ECM?
    By ringram in forum Gen IV V8 Specific
    Last Post: March 5th, 2007, 08:39 AM
  5. shift patterns with pin 71 and pin 31 questions
    By Jdperk-86elco in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 23rd, 2006, 03:20 PM
