Thread: tuning out fans
    Dec 2008
    Default tuning out fans
    I have a spal fan controller for my ls1 swapped truck so I dont need the pcm to turn on the fans. Im looking to cut all the power wires for the fans out the engine harness but I want to make sure I can do this without throwing a code or freaking out the computer. If anyone can lend any insight I'd appreciate it. Thanks.
    You should be OK as most if those are outputs with no feedback to check. Why don't you just run a relay to turn on the SPAL fans when commanded by the PCM?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Aug 2006
    I agree with Howard. I would let the PCM control the Spal relay. Then the fan on and off temps could be completely tuned with EFILive.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Dec 2008
    well thing is the spal unit I have slowly increases fan speed and everything as temp rises, it doesnt just have on/low and on/high.
    Aug 2006
    Hmmm,
    You can go to table G1203 in your tune and set the fan option to NO FANS.
    But, There aren't any trouble codes for them---So it shouldn't matter.
    PS. Are you on the 47-59 truck forum?
    Dec 2008
    Quote Originally Posted by Lextech View Post
    Hmmm,
    thanks.
    yes sir I am.
  1. electric Fans
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2013, 06:01 PM
  2. Tuning fans to AC pressure on 99-02 trucks.
    By CashDude in forum Gen III V8 Specific
    Last Post: July 15th, 2009, 04:34 AM
  3. Both fans on all the time
    By odd boy in forum Gen III V8 Specific
    Last Post: April 19th, 2009, 02:32 AM
  4. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 11:14 PM
  5. COS for E40 and fans
    By Alvin in forum Custom Operating Systems
    Last Post: February 18th, 2007, 09:10 PM
