I understand you guys say I need a wideband. It was just tuned on a dyno with 11.5 AFR across the board by a reputable shop. It is a SD tune, I have 60lb injectors. The car also cuts out in neutral or if you are steady at 3500-4000rpms. It sounds like it has a 2 step. It does not do it if you hit it at idle or less than 3k and stay in it. Any ideas?
