Results 1 to 7 of 7
Thread: Having troubles....
    New Member dmaxlover's Avatar
    Jul 2008
    Default Having troubles....
    Trying to get EFI to see the V1 cable. I am running Vista and the most current version of EFILive. I searched and read through everything pertaining to Vista and drivers. I've tried everything, uninstalling, and installing the latest drivers, and still nothing.
    If I go to the device manager, it shows EFILive is connected. I ran the USBview program and EFILive showed up on there as well.
    I need some suggestions, as my old computer that is running XP is ready to retire.
    Thanks.
ID:	4445   Click image for larger version.
    Lifetime Member MN C5's Avatar
    Mar 2005
    Make sure you install the proper drivers. Try reinstalling them if you already did it...
    http://www.efilive.com/index.php?opt...=48&Itemid=124
    Jul 2008
    I tried reinstalling the drivers many times with the same no working effect. And yes, I used the current driver download for Vista.
    Check in the properties window (Edit->Properties) and make sure you have the correct cable type selected. Or that you have "scan for all cables" checked.
    Also, if/when you install/reinstall the drivers, try turning of Vista's UAC (User Access Control) before installing/re-installing.
    Jul 2008
    The cable type is correct, and the scan for all cables box is checked. I also never have user account control turned on, and still doesn't work.
    Does this driver install screen look correct?
    Oct 2004
    The driver should show the proper device name I would have thought. Check out this section checking the device settings are correct: http://www.efilive.com/index.php?opt...12&Itemid=122#
    The drivers you should be using are in your 'C:\Program Files\EFILive\Drivers\EFILive\Win-2K-XP-Vista' folder when 7.5.x is installed.
    Andrew
    EFILive Crew
    Jul 2008
    The above didn't work, still said no device found. I was ready to give up, but decided to uninstall EFILive completely and reinstall it without screwing around with the drivers. I plugged in my V1, opened the tune tool, went to help -> Flashscan V1 PCM Licensing, and all the info was there with no error message! So I think it is working now, I'll hook it up to the truck tomorrow just to make sure tho.
  1. Key code troubles?
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2009, 07:19 AM
  2. AutoVE troubles
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 03:08 PM
  3. New laptop connection troubles
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2005, 03:35 AM
  4. Idle troubles
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2005, 05:09 AM
  5. Hot start troubles
    By PowerKraus in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2005, 10:15 AM
