Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: on the way but no laptop
    Oct 2008
    Quote Originally Posted by 8100 Power View Post
    I've seen this question asked a lot. Thanks for the link and info!
    The laptop question is the only reason I waited sooo long to make the change. I'm sure there are others. They might make a sticky out of this info after we find out for sure it works.
    04 lb7
    May 2008
    Is there any length requirement on the RJ45/CAT5 cable from the V2 to the PCM?
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Oct 2008
    Quote Originally Posted by nevinsb View Post
    I ordered 75ft. I still haven't got adapters or cable in yet but I will let ya know if it works when I get into it.
    04 lb7
    Oct 2008
    I got it Flashed Tonight with 75ft of cat 5 with no problems
    04 lb7
    Feb 2008
    i think they have released an update that will allow you to load yout tune on a sd card and then insert that to the v2. and then take the v2 out to your truck and do the flash
    May 2008
    I think they started testing the standalone flashing internally, but has not been released as a update yet.
    48 LB injectors
    T70 turbo.
    Quote Originally Posted by dt.2448 View Post
    Wow......good job...
    Oct 2008
    I would have bought an efi a year ago if I had only known.
    I have it now and I am much happier with my current setup. Thanks for the help guys!
    04 lb7
  9. #19
    May 2008
    Hmm, brings a whole new meaning to drive by wire?
    48 LB injectors
    T70 turbo.
  1. Need Laptop
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 05:54 AM
  2. Laptop
    By Chevy366 in forum Lounge
    Last Post: February 16th, 2008, 04:10 AM
  3. Laptop Died
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2007, 10:12 AM
  4. How to connect LC-1 to Laptop...
    By BlueSLPCamaro in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2007, 03:11 AM
  5. laptop requirements?
    By articSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2007, 10:28 AM
