Results 1 to 3 of 3
Thread: EXT.WO2AFR1 invalid
    Oct 2006
    Default EXT.WO2AFR1 invalid
    I have had a search on here & cant seem to find the answer. I now have a V2 with Andy's serial cable which works perfect in black box mode. However when I try to log the serial wideband pids in pass thru direct to the laptop to rtacs etc the necessary pids are staying invalid. The 2nd LED flashes signalling serial data is being recieved but for some reason the pids will not validate when connected.
    This is for an 0129005 COS5 operating system in a VY commodore. Any one else come across this problem or a solution.
    Cheers Mick
    The Tremor at AIR
    Jan 2005
    IRRC, you will need to run a PID validation while connected to V2 and the PCM to get the pass thru WO2 PID's to function. It's been a while since I've done pass thru logging though...
    Oct 2006
    Quote Originally Posted by TAQuickness View Post
    That was it. Thanks Andy.
    The Tremor at AIR
  1. Invalid Auth. code?
    By algz06 in forum FlashScan V2
    Last Post: April 18th, 2010, 09:15 AM
  2. EXT.AD1 but no WO2AFR1
    By tinindian in forum Gen III V8 Specific
    Last Post: March 30th, 2010, 08:58 AM
  3. one or more invalid checksum segments
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2010, 05:22 AM
  4. Using LS1 controllers ext pids become invalid
    By Highlander in forum General
    Last Post: August 19th, 2009, 02:36 PM
  5. Invalid PID
    By mk6gtracer in forum Gen III V8 Specific
    Last Post: July 17th, 2009, 12:13 PM
